Got the trans in and the turbo mocked up last night. Next is gettinf the crossover modified to fit
Yeah, I actually took mine to a local rad shop and had the neck moved up and had them 45 it towards the thermostat housing and it still only gives me about 1/4-1/2". Im not sure if thats close enough to fry the radiator hose or not. I'm also concerned that I wont be able to fit a blanket on the turbo with it that close. A dual pass with inlet/outlet both on the drivers side would solve my problem but I really dont want to spend another $200 on this damn thing.
Northern Radiator makes them for $200. I just really want to make this one work for now. I'm gonna clock the neck a little bit more and hopefully it will give me some more room. Did that CR fit in the factory core support ok Tim? I see you have it tucked down and in a bit more then a factory radiator would sit
