In the not so distant past I worked at a university and was responsible for the "technology" labs as well as the Electrical Engineering labs. ABET certification was a lot of fun. I would not consider going anywhere that isn't ABET certified.
I can tell you ABET is the way to go in the midwest because everyone has heard of it. Next most important is where you get your ABET degree from. In Michigan, it's largely University of Michigan, Michigan State, Kettering, and Michigan Tech that rule the roost. I would second think CMU, EMU, WMU, OU, WSU, etc for the one who gives you that expensive piece of paper if you are getting any kind of Enginerding degree.
Degrees, especially difficult to obtain ones, are largely used to weed people out. What it takes to get a OU enginerding degree is laughable compared to Umich. The same goes for what it takes to get a Spring Arbor Degree Mill University degree in CIS vs EMU. It's about perseverance much of the time. If you can survive a lot of hard classes and see it through to the end... you're probably less likely to sit in your desk at work all day watching cat videos.
Half the people that report to me have no degrees. A couple of them have degrees in unrelated worthless fields if you work in a STEM environment (say, Psychology). I look at work history first anyway. If you switch jobs every two years or less I'm not going to look at you too hard because I'm not interested in spending 1.5 years to make you a net positive just so you can use that training to get your next job six months after I make you accountable for something.
If you're just looking to fill a checkbox, call up Spring Arbor, Lawrence Tech, Kaplan, etc and they'll be happy to take your money and let you plagiarize a few papers so you can fill the checkbox.
