prostreet377
spring is out of the front seal!
I don't believe that at all. Dads 406 made 532HP on the dyno, was spun well past 6K (A LOT), and that lasted for years on a stock 2 bolt block.fastredgmc said:Just what i thought. That 4th main appears to be shifting back and forth causing those wear marks (Cap walk). The two main bolts arn't just holding it enough at that power level. Is the any metal transfer where the cap meets the block or any strange marks?
350hp @ 6000 rpm is about the safe limit for your setup there to last a good amount of time.
but if it put down 300 thats only 350-370 fwhp.
hmmmm.....
It could also be caused by in correct torque.
if you have a dial bore gauge check to see of its out of round at all.
I just get a 4 bolt block to have some better priece of mind and so it might be able to handle any upgrade later on
HemiChallenger said:Thats the whole thing, the thing has been leaking oil from the front seal since it was put together because of the crank run out. I didnt want to believe the crank was bad and though I just had a shitty timing cover or fucked up balancer. I verified the crank being out with a dial indicator mounted to the block on the pan rails out of the vehicle (obviously they were clean with the pointer on the crank istelf, not the balancer). At that point I SOHULD have repalced the crank but i was told by that machinist and another the seal should take care of that. Obviously it never did and here I am now.
I dont expect anything from the guy really but I was curious if I should take him the crank and block and rods/pistons and let him give his opinion. He already said he'd repalce the crank but as stated, I dont think another one from him would be a good idea. Oh yeah BTW it was ground .020 to begin with.
1BADAIR said:The 2 bolts blocks are stronger around the web from what I hear.
502SS said:I don't believe that at all. Dads 406 made 532HP on the dyno, was spun well past 6K (A LOT), and that lasted for years on a stock 2 bolt block.
HemiChallenger said:A fully machined ready to be assembled 2-bolt 350 converted to a spalyed 4-bolt is wayyyyyy less than a DART or World blcok. Plus 350 parts are much cheaper than 4.125 bore stuff and longer stroke cranks.
I also know 2 guys running AFR headed 2 bolt 355's. 1 runs a 150 shot on top of that, and the other runs a procharger. No problems on either of those. I do agree that it seems you're better off getting a Dart block/etc. rather than going through the cost of splaying a 2 bolt block.fastredgmc said:Thats a 400 though. Look at a 2 bolt 400 cap compared to another small block it has alot more more metal in it and alot more cap to block contact.
2 bolt 400s are stronger than 4 bolt 400's. The 4 bolt 400s are weaker because of the 400 mains being bigger and having 2 bolts per side wich makes for a lot less metal in the webbing area.
As for the other small blocks such as a 350 the 4 bolts are stronger than a two bolt. I never said a 2 bolt would not work at all but 350hp is starting to get up there and is considered about the safe point to many. 4 bolt blocks are all over and can be had for about $100-200
As far im concerned the spayed caps are a waste of time inmo. A Regular 4 bolt will do just fine for most. If you really need the splayed main setup you might as well step up to a dart block it will be very close to the price at the end but still be way stonger than the weaker GM casitng that still has its flaws in it.
Now Ill open a big can worms:icon_mrgr my 489 stroker big block is a 2 bolt main with around 600hp just shows you how much beefier a big block cap is. I am using studs though as a bit of extra insurance,
