351W
1969 block .030" over torque plate honed
Square decked
New cam bearings and freeze plugs
Stock crank cleaned and polished
Scat I beam rods with bushed pin ends
Clevite 77 main and rod bearings
DSS forged flat top pistons - full floating
Sealed Power rings
Cast iron 157 tooth flywheel
Balanced rotating assembly
TFS HR cam
Crane link bar roller lifters
Double roller timing set
Trick Flow heads
Crane Gold roller rockers
1 piece hardened pushrods
ARP head bolts
Melling stock volume oil pump
ARP HD oil pump driveshaft
Standard rotation water pump
Weiand Stealth intake
Ford Racing tall valve covers
Ford Racing Fox Body oil pan
10:1 pump gas engine
400+ HP
Ready to drop in and go.
No carburetor, distributor or headers included but they can be installed if provided.
$8000
I have video of it running I can text to you if you provide a phone number.
Square decked
Sealed Power rings
TFS HR cam
Trick Flow heads
ARP head bolts
400+ HP
$8000
