N/A SBF 8 Secound Power Plant
fast359
427 ci SBF 4.0 stroke 4.125 bore
-Dart iron eagle block 4 bolt mains on all 5
-eagle crank 4.0 0 balance
-GRP alum rods
-Diamond pistons, "2 extra"
-Crower Hippo lifters
-Trend push rods
-Canton oil pan
-MSD crank trigger distributor with new wires
-Melling HV oil pump w/ arp shaft
-Trickflow TFS R heads "RAISED RUNNER" Flow big # Done by Jeff @ Modern Cylinder Head
-Jesel shaft mount rockers
-55mm solid roller camshaft "Specs to buyer"
-ARP Head studs
-Cometic head gaskets
-SKRC Motor plate & Mid plate
-cooks S.S 2 inch headers with 4 inch collectors, Coating just done on them by Bill @ QC Coatings
-Edelbrock 4500 intake
-Pro system carb with wilson spacer
-Ford racing balancer
-MSD racing crank trigger
-Maroso vac pump with catch can
-Sheet metal valve covers
-Ford starter
-Turbo 400 trans,Trans brake,Reverse valve body,JW bell housing,aluminum deep pan, Ford racing flex plate, 8 inch converter done by Lenny @ UCC
-Motor can handle Nos.....You get carb to oil pan water pump to tailshaft of the trans all for 15k. I maybe forgetting somethings. Motor has 14 runs & Trans has 0 Runs. If you have any Qs you can call me @ 586-876-4945 thanks Bob​
-GRP alum rods
-Trend push rods
-Canton oil pan
-ARP Head studs
-Ford starter
[/wow bob nice be getting a big blockQUOTE]
