Fresh built 351W
fastford
Fresh built 351W - SOLD
450-475HP pump gas engine. 351W .030” over, roller block, ARP main and head studs, DSS forged flat tops, 10.5:1. Ford Racing I beam rods, balanced rotating assembly, AFM B451 hydraulic roller cam, double roller timing set, Ford Racing Z304 heads, roller rockers, Trick Flow 1 piece hardened pushrods, Weiand Stealth intake, Fox body oil pan, hi vol water pump, hot tested and still on hot test stand for a bit, ready to drop in. You can see and hear it run.
