91Mustang
Yeah, no kddin'. They do seem to have a fixation with trees in this city.
Trees and fruit
dang mitch, looks like the cars coming along lookslike nice work
Thanks. Will do!Looks good, ive got a lil floor work to do on my car and im done with the body. Good luck with everything keep us updated.
looks good will it be out in the spring
Thanks. I have most of the parts/ pieces to get it running. It's just the time commitment to get it done for 2009. Good luck with yours!keep up the great work mine is a complete shell and would love to have it running by this summer.
nice work!
I removed the seat support that spans the floorpan. I'll be starting on
replacing the drivers side floor pan this week hopefully. I also made
and installed some patch panels to replace the swiss cheese in the
floor from where i mounted my B&M shifter between the seats. Here's a
link.
http://s274.photobucket.com/albums/jj278/black88coupe/
+1 to you sir that car should be nice as hell when your done with it, i wish i had half the ambition as you to get my car done lol
I am doing the SAME exact thing to my 86 haha... Before you go any further, I wanted to show you something that I found.
FINALLY a place that sells the WHOLE FLOOR for fox body mustangs!!!!!
OMG FORD SHEETMETAL
Although, i will only need patches, i couldn't believe my eyes when i stumbled on that this website.
Progress looks great!
I have the passenger side floor 99.99% done. Just a couple small welds and that side will be finished. I also have most of the drivers side cut out and ready for the new sheetmetal. I installed 2" X 2" pieces of box tubing that run from the rocker panels over to the trans tunnel. I may install some tubing on the front and run it from the inner-rocker to the subframe connector, we'll see. I'll weld my roll bar to that instead of just a metal plate on the floorpan. I cut my main hoop to fit and tacked it in just to mock it up somewhat. Once i'm 100% sure that's ready i'll add the rear down tubes and finish weld that stuff. Subframe connectors will go on after that stuff is done.I'm figuring just a couple more weeks and it'll be a roller once again.
