LSX time???
Just to correct you the 628/648 was 14.5lbs not 15.5 and the 680 was 19lbs. When it saw 23lbs the tune was way soft and the pull was so short that it did not make that much power, I don't remember what it was even.
It sucks that in needs to be pulled down again but as always is will come back bigger and bader.
Ah, my bad, its been a long few days. But those numbers are even better.
Sorry to hear jon, but at least you caught it early before it did too much damage. hopefully a couple pistons will be the most youll need.
My notch will be done next week. We can cruise it and you can drive. I really cant risk any tickets in the thing, lol
Are you still gonna need to put my rims and tires on your car to see if they fit?
I wonder if you had a few injectors that were stuck open that caused you to fuel wash those cylinders? If I have some free time I will try to stop by and help
Looks like a couple cylinders are fuel washed after looking with a bore scope, no I did not drive it untuned, lidio put a baseline on it and I stayed under 2500rpm. Idk maybe an injector did fuck up..
I started tear down today, I will be trying to get it pulled asap so if neone wants to help ur welcome to, pm me if you want to come on overlol, will be working on it from 6pm to11ish
I'm still up in the air but pretty sure the motor is hurt, loss of compression and oiled plugs. Id just hate to pull it and that not be the issue
I'm still up in the air but pretty sure the motor is hurt, loss of compression and oiled plugs and my engine builder said it looks like fuel wash. Id just hate to pull it and that not be the issue
It needs to be pulled man, the comp check and bore scope video says it all. I know it sucks, but I'd rather spend the little bit extra now so it doesn't get to a catastrophic level later. Get that cherry picker out there and we'll get her done man.
~Eric
If Lidio put the baseline tune, who did your WOT tune?
