LSX Tall Deck Build
The block is machined and good to go! Here are some shots of the hone:
Tom
So progress can continue I decided to go with a 4.250 stroke Lunati Pro Series crank. I have 2.100 pins but only 6 counter weights. The crank has been micro polished as well. I have had great success with the 4in stroke stuff with over 9000rpm so I am confident I should fine. I fully understand the bending deflection across the center causes measurable losses, so many builders are using eight-counterweight cranks. From an overall engine design perspective, the LSX relocation of the thrust bearing from the rear main to the center main definitely helps reduce center-main bending deflection and will allow us to get away with alot more than a standard SBC. When the billet center balance with 8 counter weights Callies is done I will inspect the Lunati and swap if necessary. This decision has also sacrificed some displacement so I will start with a 454ci now.
Rods are next! Should get them next week. I will share the details soon.
Thanks,
Tom
