hsean1 project
i guess i can update the thread
i bought this its a 96 gt that was sprayed with rubberized coating
i sanded and wirewheeled it
por 15
i still have to change out the seals and put in a new cover
for it.
convertible doors i picked up this one need some work
a close up
i started peeling back metal
i cut out the rusted metal and sandblasted and did some welding and spackling with fiberglass and then a very light coat of filler
more parts i took to sandblast front ford motorsport sway bar and rear steeda swaybar and my cobra upper intake.
epoxy primered
red paint
arent T-top doors are the same as coupe/hatch doors, but have the window frame cut off? I think there is a rubber piece that covers this cut portion from the factory.
5.0 magazine went into detail on this in a recent issue because they couldnt find any t-top doors for their project.
Why yes...Yes they are!
yes they are but the glass is different for t-tops ,convertibles and hardtops and the window regulators for t-tops and convertibles are also different
he did sandblast that as well i forgot to snap some pics of that but you can see the finished end of it.i really thought of doing that[newer dash] but i really love the foxbody dash and i came up with this idea. this is a shaker 500 style radio but i am going to put a navigation unit in there instead.you get the idea
the faceplate is from a newer mustang and i trimmed it to fit
I love this set up!
i added another cup for the mrs.in the center console this gives it a more updated look as well since the new ones have two cups.the chrome rings will be snapped in place when its reupholstered.
i wonder if anybody has ever tried to utilize a floor mounted parking brake for a FOX, eliminating the need for that opening in the center console. It would also enable you to widen the console and make it all one even surface.
thanks man slow going and this weather is not cooperating i want to paint the suspension pieces and start assembly. how's yours coming along?
update been awhile since i posted here
center console shifter and radio bezel in stainless
started with a cardboard template
and then.....
suspension pieces
these i had to repaint and i made my own spring condensor and put these eibach springs in the struts are tokiko blues that i painted
i bought these from the village ford swap meet
got some mdf board and did alittle fiberglass work
the A-posts had a little rust so i fixed both sides and welded and smoothed the t-top brace on both sides with metal and fiberglass
the t-top trim will still go over the areas
i picked up the cervinis fiberglass hood and filled in the hood pins
the car is a roller now and i hope to have it running this summer
