hsean1 project
Engine bay looks GREAT! It's such a pain to get any detail even close to that. Good job! I've worked on a few engine bays like that and they didn't even turn out to what I would have liked...
alittle update
i spent a couple of hours sandblasting these parts and epoxy primering them
this is my oem cobra lower intake that a friend repaired for me i forgot to snap a before pic.the guy i bought it from snapped a tap in there and cut a big section off of it. it was completed drilled out and aluminum welded back in i set the spot so it can be rethreaded.
new 1993 cobra r brake booster that i sanded and painted body color
i also sanded down my new power steering rack and epoxy primered then painted body color as well
in epoxy primer
painted 2009 corvette cyber grey
the wiper motor
i installed the black dash and sound deadened the interior but my camera flash is bad for some reason
[I
MG]http://i150.photobucket.com/albums/s95/hsean/s2.jpg[/IMG]
painted this black and cleared it
thanks man just take your time and put in the effort and you'll see the same result. i spent over a month on mine.
damn its comin along nicely. whats your next steps gonna be??
thanks dave , i installed the k-member last night and i have a small gash on my forehead as a reminder.the damn stop on one of the nuts broke off as i was tightening the bolts and got hit hard.i thought i might need a couple of stitches but i got the bleeding to stop after a few minutes.the funny thing is it could have been my eye and i had safety glasses in my pocket.right now the funds are low with christmas and all. i have two small children under 6 but i already have the new black carpet and i could finish the interior but i need the t-top seals and that is going to cost me some change.i am going to focus on the front suspension i have new 93 cobra r spindles and 13" rotors i am going to do a five lug conversion.
That design for the rear seat will work. And it's much less time than I spent with how I mounted mine on my 81 coupe. I took the brace out of the 94-04 car and mounted it in the fox. That was a lot of holes to drill out. I don't know what do do this time around.
i came up with it on the fly with some metal i had sitting around the garage. i i did get the plastic brackets that the front of the 03 rear seat snap into.i have to borrow my friends welder again and fabricate a bracket to set the plastic insert into.they should snap right in then as long as i measure right:thumbsup:
alittle progress welded the brackets for the rear seat
rear seat installed
i mocked up the nav radio but the center console doesn't seem to fit right
it is an 87 and the dash is out of a 90 .
here is what i am talking about it doesn't sit flush with the tunnel
worked on my center console i fused the two sections together
here is a comparison between a stock black one i extended it by an 1.5" in the front.
i painted it here but it is going to be wrapped in leather
great work, i can't wait for updates!
thanks ,i still have to do the door panels i am doing something custom there too.the ambient lighting is a really cool feature it changes to more than 6 colors i ran alot of wiring with it when this thing is done it's going to draw some attention.
looks great...
im not sure how I feel about your ac/heater controls though. The curve of the dials and lettering dont match the curves of the trim at all. but to each his own....
looks great...
good catch it isn't staying that way it will be a complete oval all the way around the controls and i want to get the billet style controls and faceplate. i also have to extend the faceplate at the top and bottom and that the whole thing will be out of stainless steel as well. i also want to do the shifter plate around the shifter boot.
