YLWFVR
Agreed. Which is why I only got the veggie sub when I would go there, but even their bread isn't the best. Honestly though, unless you eat organic there's a ton of bad stuff in all of our food. In his case he's probably more focused on cutting calories
"So outside of the nine grains, how many ingredients does Subway use to keep this bread together? Sixteen, including such far-from-simple ingredients as DATEM, sodium steroyl lactylate, calcium sulfate, and azodiacarbonamide. But here's one that's a little unnerving: ammonium sulfate. This compound is loaded with nitrogen, which is why it's most common use is as fertilizer. You might have used it to nourish your plants at home. And Subway does the same thing; the ammonium sulfate nourishes the yeast and helps the bread turn brown.What, did you think that dark hue was the result of whole grains? Hardly. It's a combination of the ammonium sulfate and the caramel coloring. Seems like Jarod might frown on that sort of subterfuge."
