slideways240sx said:Ok heres what ive done,
Fireing order 18436572 is correct, Set timing at #1 TDC, unplugged the tan/black wire set timing at 6* base, replaced IAC, removed AIR pump and capped off all of the large lines leading to the manifolds, took off MAF and cleaned with carb cleaner
Now once i took off the maf and cleander it she seemend to smooth out and the knocking has stopped.
Whats left is a rought idle, and rough all the way thru the rpms and abslotuly NO power at all im htinking soemhtign to do with the egr or O2s? since i took off the air pump?
Clogged cat?slideways240sx said:Whats left is a rought idle, and rough all the way thru the rpms and abslotuly NO power at all im htinking soemhtign to do with the egr or O2s? since i took off the air pump?
Sean said:well it is a TPI 305 right. I am hopping you weren't hoping for HP out of that thing. Could be the EGR is hanging open. Only trouble is its underneath the plenum. I would try disconnecting the vacum line first.
slideways240sx said:If it requires to pull off the plenum i wouldent mind just deleting the entire egr system anyways
slideways240sx said:No its a tpi350, and it took the entire lenght of my road, (over a 1/4 mile) to wind out 2nd gear im going to check out the egr stuff but im not sure what lines are for what
slideways240sx said:Definitly no glowing red idle so i guess im looking at an egr problem now? I htink it might also need a new MAF since i cleared up a little when i cleaned it out. Im going to go take a look at what itll take to just delete the entire egr system
slideways240sx said:Well im the only person around here i know that has a tpi car, i dodnt know where to go form here, its missing at idle again still has no power sounds like a spark knock and backfiring under any load..... im lost form here
Does tapping on the MAF make a difference?slideways240sx said:O yea ive been on there for a few years i made a post up on there to but haven't received much yet
