393 sbf stroker motor/trans/converter
TimBoSlice
Lookin to sell my freshly build 393w motor. Its still in the car. Only has 6 dyno runs and 4 passes. C4 trans and converter are also for sale.
$6000 for it all o.b.o
may separate
Engine:
-79 351W block .030 over
-Ross Racing fat top pistons with anti-friction coated skirts done by Omar at Dart
-Childs & Albert Dura-Moly rings gapped for nitrous
-SGI forged H-beam rods
-SGI forged crankshaft balanced by Shawn at St. Clair Engines (1850 gram bob weight)
-Super Victor intake
-AFR 185 heads with new K-Motion valve springs and seals matched to the cam
-Custom ground solid roller cam from Scotty Brown .642/.642 lift 258/268 [email protected] on a 113 lobe separation (made for 250 shot of spray)
-Crane Cams link bar solid roller lifters
-Trend push rods
-Comp Cams Stainless steel roller rocker with stud girdels
-CAT SFI approved fluid damper
-Cloyes tru double roller timing chain
-ARP head studs
-ARP main studs
-Holley 800cfm carb mechanical secondary (choke milled off)
-MLS head gaskets
-SFI approved 157 tooth flex plate
-MSD Pro Billet distributor
-Ford Racing Wires (black)
-Ford Racing Fox body oil pan/pickup
-ARP flex plate bolts
-ARP Crank bolt
-Pro Comp electric water pump
-Ford Motorsports 351w 1 5/8 headers for fox body
Trans:
-stock c4 rebuild with red clutches, new steels, thrush washers, kevlar bands and seals
-stock 157 tooth bell housing
-reverse manual valve body with shift lever for a turbo action shifter
** at this time trans has no reverse. i just havnt looked at it yet
Converter:
-PTC with anti-balloon stalls at 3600 behind this engine
I will post pic later or can send them from my phone
any other questions call/text me
I DO NOT need to sell this so no low ball offers
Timmy 586-945-2905
