Last year I had the STi running great (over 400awhp). I changed to a new form of engine management, added alky, and had a "professional" tune the car, came out to 390awhp. Two months later... I lost a ring in cylinder two.
I data logged the car and read the tune. Well the professional (Tim Bailey of PDX) is a moron and gave my car a completely fucked up tune. Then found that the Magnus intake manifold had stress cracks and a fuel line had a small leak.
Parked the car and started to piece parts together.
I sent my Axis stage II engine that I had lying around back to Axis for upgrades. It is now an Axis stage III shortblock (Clevitte HP rod bearings, blueprinted engine, crank balanced to 10,000rpm, ARP headstuds, Pauter rods, CP pistons), ported heads, Axis stage II valvetrian, Kelford camshafts, 1mm oversized valves, STi shimless buckets, ported oil pump, and hardened timing belt. I also had the turbo rebuilt, up pipe thermally coated, new fuel lines, bigger alky nossle, 6 puck clutch, and I will be running the oem intake manifold. Once we get the car started and break in done. I will be switching from a pull through maf to a blow through system. Then re-tuning for the changes.
This weekend we are putting all the accessories on the Axis motor and getting it ready to be tossed in the car. Hopefully it will be back on the road within a month. :rockwoot:
Anyways, here are the pictures of the swap. There will be more to come.
pictures on pages 1,2,3,4 & 5
*UPDATE* THE CAR WAS STARTED ON 11/5/07!!!!!!
sitting for a few months...
teardown.
Motors in.
old vs. new.
damage.
Nick
teardown.
Motors in.
old vs. new.
damage.
Nick
