turbo 400 trans problem
Reverse valve body no brake...case broke and he had some guy swap internals and shifted fine and did a pass and now shift into 3rd its like someone is hitting the brakes
Who's valve body? Because ATI makes you put 1 check ball by the intermediate servo, some have you blocking off the reverse passage in the case, others are different. A important step may have been overlooked.
