jordanbmx
Used, with lifters and dogbones $80
located in wyandotte call/text jordan 734 4932046
SPECS:
Cam Style Hydraulic roller tappet
Basic Operating RPM Range 2,000-5,500
Intake Duration at 050 inch Lift 221
Exhaust Duration at 050 inch Lift 225
Duration at 050 inch Lift 221 int./225 exh.
Advertised Intake Duration 275
Advertised Exhaust Duration 279
Advertised Duration 275 int./279 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.499 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.510 in.
Valve Lift with Factory Rocker Arm Ratio 0.499 int./0.510 exh. lift
Lobe Separation (degrees) 112
Intake Valve Lash 0.000 in.
Exhaust Valve Lash 0.000 in.
Computer-Controlled Compatible Yes
Grind Number HR-224/339-2S-12
SPECS:
