6.0 LS lower end parts
Tubes92
I have for sale 6.0 LS the block, pistons, cam, crank I would like to sell everything together. The block is .30 over and is filled ,it is set up for 1/2 head studs, also have a set of Diamond nitrous Pistons and bullet racing solid roller cam that go together (Cam specs are below)motor is set up to run stock crank which also I have the crank was check by Champion and is good. I'm probably forgetting some stuff everything is in great condition
Cam specs
Grind Number CLS 311/333-14R CHEVY LS1
Part Number 500000 SN S66586
Intake Exhaust
Duration at .050 278 297
Lobe Lift .4440 .4265
Separation 114. OP CL OP CL
Timing Events @.050 29 69 86.5 30.5
Duration @.020 311 333
Gross Valve lift .755 .725
Rocker Ratio 1.7 1.7
Valve Lash .020 .022
Degree Intake Lobe to 110
Asking 1,000 obo
Located in Riverview
