SBF Pro Comp Aluminum Heads with Rockers, Pushrods, ARP bolts, and Tall Valve Covers
90blknotch
I have a set of Pro Comp aluminum heads for a SBF - I believe the 190cc version. These feature 2.02 intake and 1.60 exhaust valves and come with springs. The spring specs are as follows: 120lb seat pressure, 275lb at 0.500" lift, and max lift of 0.600". Trick Flow 6.300 .080 thick pushrods are included. The rocker studs are 3/8' and included are a set of 1.7 aluminum rockers with poly locks - I think these are summit brand. The valve covers are polished aluminum and are a tall design. They have a welded in breather and oil cap installed. Finally, a set of ARP head bolts are included - I am missing one of the short bolts and one of the step washers but it can be purchased seperatly from most performance shops. I got these heads with 1 bent intake valve - it has since been replaced and I lapped all of the valves to make sure none of the others were bent. I am looking to get $750 obo for all of this stuff.
Email [email protected] or call Sean at 734-260-0832.
