SBF (331) Rocker Selection Help.
allovru
New member
I’m in the process of putting my heads together for my Dart I/E 331 low compression block. The heads I will be using are AFR 185’s. I have yet to select a cam but I think I will end up buying an Anderson B41 cam (for a blower), I have yet to select the cam so Im not sure on what ratio roller rocker I will need.
My questions stem around what type of roller rocker should I buy? A couple NHRA friends recommended stainless steel rockers. They stated they may be a little heavier but there tolerances were generally a little better and they were stronger. This will be a street car that will see weekend recreational racing here and there.
What do you guys recommend?
Here are the rockers I have been looking at:
DSS Racing Aluminum Rockers:
http://www.dssracing.com/product_p/9000.htm
PRW Stainless Steel Roller Rockers:
http://www.andersonfordmotorsport.c...ategory_id=138&option=com_virtuemart&Itemid=1
PRW Aluminum Roller Rocker:
Trick Flow Aluminum Rockers
http://www.summitracing.com/parts/TFS-51400510/
Comp Cams Aluminum (Gold)
http://www.summitracing.com/parts/CCA-19043-16/
Any opinions on any of the above rockers would be greatly appreciated.
Thanks.
ill have a set of stainless comp cams rockers for sale in a few weeks, 1.6, including ARP 7/16 studs. only reason i am changing is i got a really good deal on shaft rockers
PM me how much you are looking to get for them and when you are thinking you will be getting rid of them. I need some pretty quick.
TFS or Ford Racing even, I think any standard name product is an acceptable choice, I would steer clear of CAT and more junk related stuff....
