patman Club Member Jan 6, 2009 #1 I need a stock SBC oil pan and a stock 4 barrel intake. Need them CHEAP
S Sean Club Sponsor Jan 6, 2009 #2 Oil pans are like $25 from summit new as for the factory intake I will poke around. I doubt I have one.
patman Club Member Jan 6, 2009 #3 Sean said: Oil pans are like $25 from summit new as for the factory intake I will poke around. I doubt I have one. Click to expand... thanks sean. I lost my job, so money's tight. bad time for a rust hole....
GrandmaLS Club Member Jan 6, 2009 #5 Those pans on Summit are junk. Both times we've attempted to use them they haven't worked out. One case we had to use the stocker and the other he went and bought a new one at Autozone.
patman Club Member Jan 6, 2009 #6 CLJohnny said: Which side do you need the dipstick on? Click to expand... passenger side
dave89iroc Club Member Jan 6, 2009 #7 patman said: passenger side Click to expand... 1 piece or 2 piece rear main seal? 2 piece was 80-85/6, 1 piece was 86 up
patman Club Member Jan 6, 2009 #8 dave89iroc said: 1 piece or 2 piece rear main seal? 2 piece was 80-85/6, 1 piece was 86 up Click to expand... I'm not sure what year the engine is. How do I tell them apart?
DarkoStoj A mysterious figure named Darko Jan 7, 2009 #10 i have a weiand stealth intake for a sbc you can have for $75. I also have a pan here lying around with a newer oil pump and pickup
patman Club Member Jan 7, 2009 #11 got an intake, how much for just the oil pan? where are you located?
