s10 tire wear issue
Swats
My father drives a 2002 2wd Chevrolet S10. The truck has about 71,000 miles on it. At about 40,000 miles he got new tires on the truck from Sears. I believe the tires are Michilens (spelling?). The rear tires seem to be fine with very little wear. On the front tires some of the edges on the treads blocks are slightly raised up. While going down the road the tires make a fair amount of noise. My father decided to go back to Sears to see if they would do something about the tires. They told the tires are cupped from the front shocks being to soft. The truck drives fine to me. I drove the truck to Ohio a couple of weeks ago. It was about 300 miles round trip mostly on I-75. My only real issue was the tire noise. One thing my father said is that he has never rotated the tires, because they are radials (I believe he is wrong). So would lack of tire rotation cause cupping? Or could the front shocks be the cause even though the truck drive fine?
Lack of rotation CAN and does cause cupping. You should have your tires rotated every 10k at the very least. I dont know why he would think they dont need to be rotated because they are radials. It could also be out of alignment, and soft(bouncy) shocks will also cause abnormal tire wear. Hell even ball joints and tie rods will cause that. Shocks are recommended to be replaced every 50-60k so it wouldnt hurt to try that along with normal sceduled tire rotations.
