Project Ressurection
Back to the Mother Fucking Top. Check out my needed list In the parts wanted section to see if you can help get this thing on the road!!
Car is at Diamond Race Cars in Ohio for some thru the floor sub frame connectors and repair work to the front frame rail. Should have it back in a couple of weeks and then my goal is to get it sitting on the ground on all four wheels. Ill post up pics when I get it back(w/ flash).
Picked up all new Team Z front and rear suspension for this car. ...
Team Z strip series Upper Control arms
Team Z Double adjustable lowers
Team Z K member
Team Z A Arms(1"shorter)
Strange Coilovers
Strange 10 way Adjustable Shocks
Strange Front Struts
Strange Front Brakes
Once I get the car back I will get all this installed and be looking for a nice set of wheels. I will post pics once car is back in my possesion.
93 red is a sweet color....I beleive the code is EP. Oj would know for sure tho.
Sent from my ADR6300 using Tapatalk
Cool project. Not sure if you have started painting your interior pieces or not. Prep them using a fine scotch brite pad and wipe with lacquer thinner. Apply a couple thin coats of SEM plastic panel prep or adhesion promoter. O'Rillie's sells an off brand made by DuPont that works just as well as the SEM stuff and it is 1/3 of the price. It is master craft or something like that. Make sure you use a paint gun and not a spray can. Also, be very careful not to put on too much. It is very easy to washout the grain. Thin coats are key. Your first coat should be spotty. It just makes things tacky so the final coats stick.
I am sure you posted it somewhere, but what engine is that? Is it a 4.6 2-valve?
Glad to hear your making progress again. Is my phone broke? I don't see any updates pictures since the first few you put up
No pictures yet, car is off for paint and when it returns I will post pics then. Wanna donate some parts to the build? lol
Paint on the trunk lid and doors look awesome. Went and checked it out tonight, and can't wait to get it back to start bolting up new parts on it.....
