99slverZ
Well, I've wanted to paint my engine bay for some time now. I was talking with Smooth to have him do it, and his prices were extremely fair. However I had to have some work done on my shortblock, and its not gonig to be cheap. So I decided to try and keep this as "budget" oriented as possible.
This was done using Duplicolor rattle can paint, clear, 250-1200 wet/dry sanding, AND minimum paint experience. :scared: I think it came out OK, around 4-5 hours of labor. I'm sure it would be much better if I had someone who knew what they were doing paint it, but this saved me a lot of money. Cost around $28 total, and if you know what the stock Fbody towers look like, you can see its a major improvement. :1syellow1
Those hoses are getting new sleeves, so I wasn't worried about overspray on those. The actual metal is very uneven, with lots of ridges. Really rough to work with. A lot of guys use bondo to smooth everything out. I just didn't have the time frame, or skill to do all that.
Not the best but you get the idea.
These pictures are about 20 minutes after the final clearcoat, its a bit more glossy now. Should look really good once its waxed, just didn't have time before the work week started.
