oil pump problem
Sound and looks to me there is to much pressure in the crank case blowing out the gasket and seal.
There is no oil pressure behind the seal or gasket. there is only pressure in the gallories and in between the crank and bearings.
If there was to much preesure the oil filter would burst, usually the first sign ive seen it many times.
70or so psi isnt that uncommen when the oil is cold
what is all the shit in the sumo of the oil pan? im not talking about the gasket pieces
Blow by will not cause it to leak out of the main like he said it was. to my understanding it was leaking right on start up or when he was priming it. That is where he needs to check & make sure the galleys are clean.
priming it pegs the gauge. it starting pissing out the pan/rear main after running like 10 minutes. The rear main is actually fine. It was leaking out the 2 spots on the pan gasket shown in the pics and where the rear main is...it actually sucked the gasket in by the main.
