nitrous for LT1
Imnotfast said:
The big thing to remember with the MAF kit and a LT1 is the TB. IF you use it with a stock TB least have a airfoil to help guide the fuel around the dead zone between the blades. Or you can run a Mono-blade TB, AZ marine had them on sale right now for under $500.
For plate systems I liked the Nitrous Works system better the NOS's its $100+ cheaper for the same stuff - the extra fuel pump. You really should have a upgraded fuel pump anyway.
i dunno... all the stuff ive seen Nitrous Works Vs the NOS system the Nitrous works actually blow up alot more.... last couple guys i talked to said they ran into alotta bad solenoids with the Nitrous works kits....
Thanks for the info. Never had a problem with mine but it could have been a wed. build.
