to explain between oil leaking out first i must ask have you ever worked on a similar engine? then you would know that the oil pump is located on the outside of the block, just behind all the pulleys, and connects to the oil pan as well. Between the oil pan and the oil pump It might not have got sealed all the way when i put it back together. ( me being lazy and just took all the pulleys and wheel off and just installed it instead of pulling engine to do it). does that answer your question.
then to the ranger question, i use to wn a 93 single cab and I was going to do it to that but then the parents sold it, do I was thinking the same body style 93-97 i believe are the correct years. You can buy the little parts you need to do the V8 swap, and the 302 is only 100 pounds heavier than the stock 4 cyl. So i would either do the 351 or a 302 swap in it, jsut with the 351 you have to get block huggers for clearance issues or just cut some of the fender well (sp?)
