OrangeF150
Ok....some one school me on this.I am measuring what length push rods I need.I got my lifters installed, both exhaust and intake are on the base circle.I know you put the adj. rod in place and adjust it up to the rocker.I do not have adjustable roller rockers, just the factory stamped rockers.When they are torq'd down to 28 ft lbs, I know you want like .060 pre-load on the hydrolic lifter, but should there be a gap between the rocker tip and valve tip or no?If so how much? Does it matter that these are BRAND new lifters nad might not be pumped up 100%> I have always had valve train noise from not doing it the right way, and I would kinda like to solve that this time:flashboob..please help trying to get it out for cruise night on friday
