Guys, you have to remember, it's not just the total amount of airflow the unit is rated at, it also matters where the turbo is at on the map.
The turbo I ran was a GT42-76, much stronger turbo than an old school t-76. If you look at the map, that 4276 would actually have been much happier on a smaller motor....which is why Brian is such a cocky mofo about his car lol...that turbo will make more power on a smaller motor than it did on my car.
The T76 is the same way. It might make 1000hp on a supra, but I don't know if it will make that much on Dan's car. I know it sounds fucked up, but that's part of the turbo learning curve. Who knows, it might even make 1000 on a real shitty 302, but not on Dan's bad ass "302".
Here's a real word example: Take that GT42-76 I ran last year. 3200# Mustang, kind of a shitty 347 cubic inch motor with faggoty cylinder heads that won't rev past 6000rpm. 155mph @ 3200#.
Take that same turbo (exact same A/R and everything) and put it on a bad ass built 370cid LS1 with nice heads that revs to 7000rpm. My buddy's did that. The car was a slug bitch. The turbo made boost, but the car was a turd, ran like mid 10's. Take that overworked 4276 off, bolt on an S88, and that same car goes like 150mph on the limiter at 1000ft. That car will probably exceed 158mph now that it has the proper turbo on it.
If you look at the map, the data tells you the reason. If you take the airflow consumption of a each motor at the given boost level, and see where it is on the map, it's happy on my car, not very happy on the superior motor. That T76, on the map that I looked at, will not be happy on Dan's motor. Just my never very humble opinion.
