Aluminum block, standard bore. $225
Teksid Aluminum block .020" over $250
4.6L Romeo cast iron block, ran fine when pulled for performance swap. Had about 80K miles on it $100
4.6L Romeo cast iron block, washed and rough bored .020" over, $200
5.4L Windsor cast iron block, ran fine when pulled, had $90K miles on it $150
5.4L Windsor cast iron block, washed and rough bored .020" over, $250
4.6L 6 bolt crank $50
2V Windsor PI heads $125/set
2V Romeo NPI heads $50/set
4V rods with bearings ,like new $40/set
New 4.6L 2V Mustang 96-04 exhaust manifolds $75/pr
New 4V Mustang 05-up exhaust manifolds $75/pr
4V Cobra, Mach I, Marauder cams low mile take out $75/set
4V Navigator intake cams new $50/pr
4.6L 2V Mustang oil pick-up tube $25
4.6L 4V Mustang oil pickup tube $50
4.6L 4V Mark VIII oil pickup tube $50
Cobra oil pan with oil level sensor $100
Cobra oil pan with oil level sensor and weld on oil drainback $200
Mustang oil pan with hole tapped for oil drainback $50
Explorer oil pan and pickup tube $75
Van oil pan and pickup tube $20
Crown Vic/Grand Marquis oil pan $20
3V S197 oil pickup tube $35
3V S197 heater tubes $35
3V S197 oil dipstick and tube $20
3V oil pump (new) $50
3V P/S pump/ spacer and pulley (new) $75
3V S197 air induction hose $20
3V stock cams $35
94-95 Tbird front cover $75
Explorer front cover $35
96-98 Mustang 2V front cover $75
99-00 Mustang 2V front cover $75
5.4L front cover $40
Cam covers:
Windsor passenger side w/modified fill neck $10
Romeo drivers side w/fill neck $15
Romeo drivers side w/o fill neck $15
(8) JE .030" over dish pistons (measure 3.576"-3.578") $100
(7) CP/Mod Max .030" over 19cc dish pistons $75
(6) Ross .020" over 16 dish pistons 99806 $75
3V stock cams $35
Cam covers:
