wikdsvt
MY New build is done and I have some left over parts.
Prices include shipping
Add shipping costs to all prices listed.
most parts are for ford lightning
4R100 Factory Tech Stall Convertor $400.00
Ford 5.4 2v Stock heads, gasket ported and a little more, inserts installed in each spark plug hole
$300.00
Crower Stage 3 Cams 62-803-2
Ford Modular Camshafts
Ford - 4.6L & 5.4L 2 Valve Late Model
Performance level - Stage 3 - Street/strip profile. Emphasis on top end power. Spring required.
INT/EXH - Dur @ .050” Lift: 220°/224° RR: 1.8/1.8 Gross Lift: .590”/.601” LSA: 114° RPM: 1750 to 6750 Redline: 6750 Note: All Crower 4.6L & 5.4L Camshafts require 86053 cam bolts. Stock cam bolts will not work with these aftermarket camshafts.
https://www.crower.com/ford-4-6l-mod...pair-4727.html
New: $720.00
Sell for $300.00
JLP AIRBOX (No filter). MAF bolts right to this box. Use stock rubber or aftermarket boot from TB to MAF.
$75.00
Stock 42lb injectors, rebuilt . New filter, seals, pintle caps from www.Mrinjector.us With 42lb calibrated 90mm aftermarket MAF would prefer to sell as a set as they are matched. Would work great in lightning or upgraded mustang. $300.00
TURKEY PAN One is ported to match the heads above. has 99-00 supercharger bolt pattern. Its spray painted with chrome paint that is peeling off. Looks bad, but take a wire brush to it and you're good to go. $75.00 Prefer local sale as shipping would be a bitch.
TURKEY PAN stock 99-00 supercharger bolt pattern $100.00 Prefer local sale as shipping would be a bitch.
Mid Plate 99-00 supercharger bolt pattern $75.00
Ford 5.4 NVH Grade 2 block. $200.00
Ford Lightning forged crank $150.00
Miscellaneous 5.4L pistons. $75.00
(3) Manley pistons 57008, 1703 594130
(4) CP/ModMax pistons
(1) Ford pistons 090263k2 (new)
11 wrist pins
a pile of pistons rings
Factory supercharger lower pulley (removed with 3000 miles) includes bracket
$100.00 (these are getting rare)
6lb lower pulley ring, will fit Metco adjustable pulley hub $50.00
EATON upper Cog pulley. Needs metco upper adjustable supercharger pulley hub
BRETT White Made. New its $225.00 https://www.ebay.com/itm/Eaton-Cog-P...tVZz24&vxp=mtr
Sell for $150.00
Supercharger belt for 6" lower pulley and stock upper pulley $30.00
99-00 Steigmeier ported Eaton supercharger. (current port job is $600.00) The silencer holes are sealed.
$400.00
Ported and polished upper plenum $150.00
phenolic spacer, between supercharger and upper plenum ford Lightning with longer bolts and spacers for bolts $50.00
99-00 metal gasket between mid plate and turkey pan $40.00
01-04 metal gasket between mid plate and turkey pan $40.00
01-04 metal gasket between supercharger and mid plate $40.00
2013-2014 Ford Mustang GT500 factory Cold Air Intake with factory air box and factory cloth filter $75.00
2013-2014 Ford Mustang GT500 Air Raid Air filter (looks like K&N filter) $40.00
I will have more parts as I come across them. My truck had 57k miles when I removed most of these parts. Located in Milford, Michigan.
I work a shit ton of hours, so if I do not immediately respond, be patient.
$300.00
New: $720.00
Sell for $300.00
$75.00
11 wrist pins
Sell for $150.00
$400.00
