DarkoStoj
1 holley strip dominator intake for big block chevy rectangular port, good shape $100
1 new set of edelbrock chrome valve covers for big block chevy $30
m/t aluminum finned valve covers for sbc $30
msd digital 6 plus ignition and blaster hvc II coil(was $130) $300
barry grand bg220hr fuel pump 220 gallon per hour with bg5000 fuel filter, -10 feed and return hoses with diaphragm bypass regulator $400
turbo 400 trans with converter, ready to use $250
tci turbo 350 tans with torque converter, great shape ready to use $400
10 bolt out of a 1967 camaro with new 3.55 gear and eaton posi, have 1k recipt for work done to it $500
18x8 konig trouble wheels for a ford bolt pattern 5x4.5. 6" backspacing $300
aeromotive gas tank sump summit has it for $150 I'll take $100
competition engineering gas tank sump $40
stock 1967 camaro gas tank, good shape $35
1 set of 993 casting sbc heads. I used them on my blower motor to drop the compression..also the exhaust ports have been opening up. Cleaned up with comp cams valve springs, ready to bolt on $250
sbc comp cams xe274 cam 230/235 @.50 .490 lift 110lsa perfect shape $75
holley 80575s 600cfm mechanical secondary blower carbs. Cost me $750 each. They are in like new condition $1000
weiand stealth intake for sbc $100
world sportsman sbc heads just pulled off motor 72cc chamber $450
11" heavy clutch off a chevy with 10 spline 1 1/8 input shaft, plenty of meat left $35
tremec 3550, lakewood bellhousing, centerforce dual friction clutch, and short throw b&m shifter $1400
chevy 350 4 bolt main shortblock $250 (have 2 of these)
ford motorsport double roller timing chain, new in box $45
pressurized tank sandblaster works very well $150
new in box ford clutch for t5 transmission $50
rear bumper and taillight panel out of a 93ish camaro, lighter metallic blue color $100
black 1967 mustang door panels, new in box $50
1969 mach 1 hood scoop $50
new black ford motorsport valve covers $75
new stamped chrome small block ford valve covers $40
1967 camaro power steering box $30 (have 2)
set of ponies with mickey thompson ET streets, great shape $400
eleanor upper and lower side scoops for 1967 1968 mustang fastback, new $300
chrome long water pump for sbc $25
walnut grip grant steering wheel with chrome 3 spoke $75
1967 camaro upper cowl, great shape $40
brand new leaf springs for 1965 to 1973 mustang $200
1991 corvette c4 complete passenger door $75
box of brand new comp cams pushrods for big block chevy, make offer
1 brand new set of sce self sealing copper head gaskets for a sbc 350 .030 $100
1 brand new set of flat out gaskets rubber coated copper head gaskets $100
2 1/16 autometer ultralite vacuum gauge $45
sbf 302 timing gear drive new in box, make offer
1967 1968 mustang fastback and other years? fold down rear seat in black, make offer
chevy straight 6 out of a pickup truck with 4 speed manual trans, looks nice, complete $250
fox body mustang power steering pump and misc interior/seat parts, inquire and make offer
complete front drum brake setup off a 1967 camaro, these actually worked very well in my car $75
new front cross drilled and slotted front rotors and hub for first gen camaro with bearings and seals $150
camshaft out of a chevy 350, unknown specs (havent pulled it yet) but had quite a bit of lope at idle and 10" of vacuum $35
I have about 3 or 4 mechanical fuel pumps for a chevy, inquire about and make an offer
COMPLETE 1988 porsche 944 wiring harness, chassi and motor, everything uncut, make offer (also have many other parts off this car, inquire if you want more details)
1965 mustang fastback shelby gt350 clone 289 a code 4 speed, nice shape (its my brothers) $23k
1967 camaro big block 454 4 speed borg warner t10 transmission, solid $15,500 or trade
chevy 350 flywheel $50
chevy 350 flex plates $35 each
1967 camaro power steering pump and resivour $40
ford 9" 3rd member gear unknown open diff $50
ford 9" 8" axleshafts for 1967 to 1973 mustang with a 8" or 9" 28 spline $150
nice new looking power brake booster and master cylinder for fox body mustang $50
I just listed this stuff off the top of my head and have more that I'm sure I'm forgetting
248-506-5916
[email protected]
248-506-5916
[email protected]
