standy
and also in your opinion what would be a better all around dd, work horse, versatile truck, interior and comfort arent high on my list, i enjoy both interiors and feels equally. i just want a truck thats reliable and will last me a long time and that fits my needs
Honestly, I think either would fit your needs well- it all comes down to what you can find that fits your price range. The IFS on the GM trucks has gotten a bad rap when compared to the solid axle trucks, but it actually holds up quite well. For example, most of the big power trucks are doing 20psi 4wd launches without any damage. A set of tie rod sleeves and some supports for the pitman and idler arms make it a pretty good set up. Still not even close to the toughness of a Dana 60, but for most applications, plenty strong. That being said, I would probably pick the GM for an all around truck, as long as I wasn't hauling a huge, super heavy trailer (like tractors, farm equipment, etc.), or plowing a lot of snow. The only real reason I wouldn't want to plow with my Chevy is the fact that the front end isn't nearly as tough as a solid axle truck, and reverse with the Allison trans is painfully slow if you're trying to back up fast.
I would recommend driving them both and then thinking about it for awhile- When I park my plow truck and then jump in the DD, its like getting out of a dump truck and getting into a nice car....but that's just my feeling. I would say that you can't go wrong either way, and after you drive both, your decision will be easy- they are so different that you will definitely like one more than the other.
