SVT32VDOHC
Looks like that thing pulls harder from 120-200 than most cars pull from 20-100. :lol: Nice vids!
WOW thats sweet ..........
What do the heads flow after you cnc them ? stock valves ?
Did you mill the heads ?
What is the specs on the stage 3 camshaft ?
How much more hp/tq do you think it would make with Carries (ETP) carbed cnc`d intake and a carb/dominator ?
Thanks for all of the replies!
Peak numbers were 386 on the intake and 234 on the exhaust. Low and md numbers picked up quite a bit. The factory head stalled at around .650 lift and we fixed that issue. I'm hoping to have graphs soon.
We used stock valves and milled them slightly for trueness.
As far as cam specs, Dan did a lot of development on the dyno and tested a lot of cams and we typically always give the specs, but lately have been noticing a lot of people copying our grinds. He would like to keep these specs proprietary.
We didn't do testing with a carb manifold, but I would guess it would pick up quite a bit.
Thank you,
Rick LeBlanc
Livernois Motorsports
Peak numbers were 386 on the intake and 234 on the exhaust. Low and md numbers picked up quite a bit. The factory head stalled at around .650 lift and we fixed that issue. I'm hoping to have graphs soon. EDIT JUST TO SPECIFY, these numbers were from a SuperFlow 1020 bench calibrated with plates borrowed from the OEM and a SuperFlow 600 would read roughly 10 CFM more.
Thank you,
Rick LeBlanc
Rick,
I Really didnt want to, but im tempted to mod mine now.
any other Sound clips or vids?
How Idle, Driveablity? any Stalling issues or anything at all?
Rick,
It idles great and in all honesty, it drives pretty good considering the size of the cam. I wouldn't recommend it to someone with a daily driver or that was worried with great drivability, but I'm pretty picky when it comes to drivability and I would definitely have no problem with it in my weekend toy.
Here is another video of it...
Click
-Rick
I guess what im saying is, does the cam make the car Shake on idle or low rpm cruising?
UPDATE - Last night in Orlando, the car went 9.95 @ 139.18 MPH!!!hmy:
Trying to get a better slip... this is all I could get so far (hard to make out though)
-Rick
any vids?
It went 9.51@ 148 then 9.45 @148 Wednesday night on the hose :jawdrop2:
-Rick
