95 Z/28 LT1
My Camaro needs a higher output alternator to run additional accessories such as electric water pump, trans cooler fan, large fuel pump, pump controller, etc, etc.
The model I need is quite common, it's a CS144. When I search online, I see a lot of variation in offerings for different amperage and suppliers, warranties, etc. I did more reading and found that in some cases a high output alternator will deliver lower voltage at idle, and that's a trade off. Is that true?
I'm looking for something in the 220-250 amp range. I see triple, dual, and single bridge rectifiers, HD regulators and/or self igniting. 300 volt, non-avalanche diodes and the jargon goes on.
What and who have people had good luck with and what are the hidden issues that can arise? I want something that is good quality that will plug in to the factory harness and connections. However, my alternator has been relocated.
