GM LSA Blower w/ CTSV lid, LSA injectors & Throttle body
NBFRC
Used LSA supercharger which was a warranty replacement. Pulled for a worn coupler which has been replaced with a new solid coupler. Car had 46k miles when pulled. Supercharger is in good working condition. Also have a used ctsv lid w/intercooler brick, used LSA injectors and throttle body all from the same car.
$1,350 Items are located in Warren at 10 & mound.
call or text 989-787-2017
So what motors could this be used on? Just a CTSv?
5 seconds worth of research square ports LSA
Yep, pretty much any ls motor which has the square port heads. There are a couple of different options for the front pulley drive, as long as you have enough clearance for the stock truck accessory spacing you should have enough room for the front belt drive.
Heads square port L92, LS3, and you might still not have the room in the front of the engine, this bracket uses the truck water pump spacing which is 1" further forward. I also think the AC would need to get checked.
you would need the fuel injector rail
You would need someone to tune for it
You would need to make a IC cooling circuit and mount the resistor and heat exchanger
there is probably more stuff you would upgrade over time (fuel pump, injectors??)
