jankab
GI: 500+ HP 351 Cleveland, C4, TCI and fox swap parts (k member, headers, etc.)
This used to belong to LightningJeff, he told me the engine made 512.3 HP at 7k rpm with a 750 cfm when he had it.
I am gauging interest if my notchback roller sells, no price set as of yet so I am open to reasonable offers I have a lot invested into this setup.
I will not part out, I may sell the trans and coverter separately. I will consider trades for a built efi stroker of similar value to put in my 87' Mustang GT.
I got it from him and tore it down to do a refresh:
Fresh 72' 351 Cleveland .030
TRW 10.5 - 1 Forged Pistons with new rings
Custom ground Solid Roller Laser Cam 735 intake 738 exhaust
New rollers
New push rods (I believe they are hardened)
Stock Cleveland Rods, casting cleaned up with ARP rod bolts and new bearings
Stock crank polished, casting cleaned up with new bearings
Fresh unported 4V heads with ARP head studs
Ferrea titanium valves, new springs/retainers and valve job on 4V heads
Torker 351 Intake
CSR Electric Water Pump
1.73 FMS roller rockers
Jomar Rocker Stud Girdles - I have to double check they are Jomar almost positive
MSD Distributor
MSD cap and 8.8 wires
Canton rear sump oil pan
Tall Motorsport Valve Covers
Custom motor plate - foxbody
No carb
The bottom end is all together and assembled to spec, the heads need assembly and install - I have the headgaskets and intake gaskets also.
Hooker 1 7/8 2 piece headers - foxbody
Tubular k member with tubular control arms and Flaming River Rack - foxbody
New rollers
Torker 351 Intake
MSD Distributor
No carb
