Fuses for back running lights
Check fuse #4 and check the wiring to the headlight switch for loose/melted connections. A wire might be melted away within the socket to the switch. Look for it from under the dash on the driverside kick panel.
Measure the voltage between headlamp switch C205 Pin B2, Circuit 195 (TN/WH), harness side and ground.
Is the voltage greater than 10 volts?
Yes
GO to L2.
No
REPAIR the circuit. TEST the system for normal operation
Measure the resistance between headlamp switch C205 Pin R, Circuit 14 (BN), harness side and ground.
Is the resistance less than 5 ohms?
Yes
INSTALL a new headlamp switch. REFER to Lamp Switch — Headlamp. TEST the system for normal operation.
No
REPAIR the circuit. TEST the system for normal operation.
Place the headlamp switch in the parking lamps ON position.
Measure the voltage between inoperative lamp connector Circuit 14 (BN), harness side and ground.
Yes
REPAIR Circuit 1205 (BK) for an open. TEST the system for normal operation.
No
Are the parking, rear or licences lamps on?
Yes
REPAIR Circuit 14 (BN) for a short to battery. TEST the system for normal operation.
No
Glad you got it figured out.
The issues that pop up during a repair that have nothing to do with what you did ALWAYS throw people for a loop. Just gotta keep the diag simple and systematic.
