82hatch
fyi on used areomotives, the manufactures date is stamped on the bottom..
i'm getting ready to rework mine shortly. i need to resump the tank because of cavitation issues. also need to rewire, i had a slight flammage problem...
so how big of a fuse should you have on an A1000? i ran 10 gauge to the rear. any special requirements on relays? something happened with mine and i'm not sure what...
also, people that run braided up front, where do you route your fuel lines? tunnel, sfc or what... my first thought was to run inside the car through the front up to the engine but it seems i heard the tracks want it outside the cabin... seems more protected inside.
Pretty sure you can't run fuel line inside the vehicle per NHRA rules. May end up just getting a new A2000-hard to beat the price. Limige-good wiring question-haven't even thought of wiring yet.:lol: How/where did you mount the pump? Did you use -10 line?
