xcoldricex
4 lug skinnies with brand new (still has nubs on them) Kelly 165r15 tires on aluminum space savers with machined holes. offsets seem to be very slightly different - $75 obo
2x 10 hole mustang wheels with new Fuzion HRI 225/60-15 tires $75
http://lh6.ggpht.com/_aBp3AM4SXfs/TTMv39wn7zI/AAAAAAAAB50/N-i1LdAq-pw/s640/DSC07331.JPG
2003 Cobra Terminator OEM A-arms with Prothane Urethane Bushings
$300
These were never used, one needs a new balljoint though (it was heated up and the boot burned) but you could run it for awhile before replacing it if you wanted. I ended up needing tubular arms to fit with my k-member/headers, so I never used these.
Interior:
Grey interior panels - no dash, no door panels. $100
Grey tweed seats out of a 87 gt, just some staining that can be easily steamed out, otherwise in very good condition with no tears/cracking. Was going to use these but found some racing seats. $OLD
Red ones - drivers side has a small tear and vinyl cracking on the left shoulder, no sliders. $OLD
Fox body LSx swap long tube headers $200
Not clean, not coated, some massaging done, but they get the job done. Stock steering shaft and k-member with modded mounts (below) were used with these headers.
Stock F-body radiator and dual fans - $125 (no modification needed to fit fox body for the lsx swap)
I have the 4 lug spindles and front disc brakes if someone wants those too.
Rusty Stock K-member solid LSx mounts with arms, rack, and custom transmission mount for LS1/TH400 Swap - $OLD
2 Flowmaster mufflers - $OLD
$300
Interior:
