FS: Brian Mitchell's EFI Renegade SBF Vic Jr Castings/Titanium Valves/Retainers/Locks; Need Repair
PaxNovi 5.0
EDIT: Bought some stuff and made some money on other parts. $600 takes it all.
Selling Brian Mitchell's old EFI Renegade SBF Victor Junior Castings and Titanium Intake Valves, Inconel Exhaust Valves, Titanium Retainers and Titanium Locks. According to Brian, there is nearly $10,000 of development into these heads. They have been very fast/quick.
-Flow 335 cfm by .600" lift
-2.09" Titanium Intake Valves (as documented below, there are 3 different types, but they ARE all usable and in very good condition)
-1.60" Inconel Exhaust Valves
-Titanium Retainers
-Titanium Locks
These ARE in need of repairs. If you have a friend that is good with aluminum welding and/or cylinder head repair, then these are for you. Have them repaired and add your valve spring of choice, and you will have a great set of proven/championship winning cylinder heads.
Here's a list from Roush documenting what needs repair:
http://www.motownmuscle.com/forums/...raautomotive&p=2721697&viewfull=1#post2721697
Here are pics:
http://s8.photobucket.com/user/PaxNovi9150/library/Heads?sort=3&page=1
As said, these ARE repairable. I just don't have the time/energy to have them done myself and have a different set and style of cylinder heads coming, so these need to go.
Price is $900 FIRM for everything listed in the ad. The hardware alone is worth that or more, let alone the castings.
I am located in Port Huron and am in Wyandotte for work during the week.
Feel free to call or text me on my cell: 810-434-8653
Will trade or do partial trade, up or down, for a multitude of items:
-Aftermarket 8.8 Rear End Girdle
-5 Lug Rear Wheels x 4.5" with 10" width and 6.5" backspace
-5 Lug Front Runners
-275/60/15 Drag Radials
-Radial Front Runners
-Aluminum Driveshaft
-AOD Transmission with Transbrake and O/D switch
-1.72 or higher ratio Roller Rockers
-Stud Girdles for Twisted Wedge Heads
-Or Shaft Mount 1.72 rockers for Twisted Wedge Heads
-A set of quality hydraulic roller lifters
-75mm Throttle Body & Spacer
-Aftermarket Fuel Rails
Etc.
Heads are at Rusty's shop and will most likely be fixed upon his quote. If fixed, they WILL be fixed properly and price will go up accordingly!
You buy these heads directly from Mitchell?
No sir, I didn't. Brian is a good guy!
Bumping these.
I am switching directions regarding the type cylinder head I'm using in the build and opted not to fix them, but to sell them as is. As mentioned, they are definitely repairable, and I can put any interested parties in contact with Rusty at P&P to verify this.
I just bought a ton of parts... That said, $750 cash, absolute bottom line. I was advised by several cylinder head guys to take no less. Otherwise they sit. No tire kickers, serious parties call or text me.
Looking like someone from YB will probably be purchasing these tonight. So if any locals are interested, please speak now!
Updated list of things I'd trade for:
-5 Lug Front Runners 15" x 3.5"
-275/50/15 Drag Radials
-Powerglide with 1.80 straight cut gear set
-1.7 ratio Crane Gold Rockers for 7/16" Studs
-1.6 ratio Crane Gold Rockers for 7/16" Studs
-Or Shaft Mount 1.6 rockers for Twisted Wedge Heads
-Or Shaft Mount 1.7 rockers for Twisted Wedge Heads
-Double adjustable shocks for use in the stock rear location
