Birdie2000
So I have a 4th-gen F-body and need a new rear but my budget is limited and there's not much of a middle ground in terms of pricing for this application. I've been particularly indecisive about this because it's basically rebuild my stock 10-bolt for about $1k (which I am considering) or spend $3k+ on an aftermarket (I really don't want to spend much more than $2k). The car will have a twin-turbo setup and will likely be in the range of a 500rwhp with a T56 and I will be daily driving this car so I want it quiet and well-mannered. I don't need anything crazy but rebuilding my stock rear is a gamble at best with a manual at that power level even without taking it to the track. Also, the used market on aftermarket rears for these cars is basically non-existent unless you want something with a spool and steep gears.
I've found two options that come reasonably close to my intended price point and those are either a custom hybrid 8.8 setup or I've found one vendor that has a an affordable 9" housing/axle package that I could use to piece together a decent rear for similar money. Both would probably be fine for my power level.
I'm completely unfamiliar with Ford differentials and gearsets and this is where I need help: My main objective in all of this is that it needs to be dead silent and drive well since this is a daily driver application. My questions are as follows:
1) Are there any differences in the noise between the gears/etc. available for the 8.8 and the 9"? What gear manufacturer/type would you go with for my application? I'm looking at a 3.30-3.50ish ratio. I've heard a lot of people say that the 9" tend to inherently be noisy while the 8.8s are pretty quiet. What is everyone's experience on this?
2) People seem to think that the Ford Racing Trac Lok with Carbon clutches is more than adequate for that power in an 8.8 while still being quiet, etc. Does this diff also exist for the 9" and have the same noise/strength characteristics?
3) I've heard something about needing tapered bearings for frequent street use with the 9"? Can anyone elaborate on this?
4) Any other noticeable differences between the two I should be aware of for my application?
