eye see nothingFixed smartasses :thefinger
front axle
should have no problem with the diff section itself once you get the right gears.
Did you measure the diff at all???
Yes, end to end is the same, bolt pattern is the same for the ring gear, lateral dimension for the gear is the same and accepts a 31 spline. Just shaped a little bit different. maybe an updated year?
Front Diff gears
