X2 Agreed, If it is nosing which it sounds like it you need to richen it up a bit.Check the A/F ratio, make sure it isn't too lean at cruise.
Steve
That is possible, along with too light or broken dist. weight springs!timing
Gary Kook is up there, Greg Cernie At Great Lakes Customs, Bruce Kimmins over at Top Craft...John Vermerche ToTal Performance ...Lidio over at Extreme...They al can do that header!Plugs are black, so I don't think its too lean. Timing is a good point. I set it up to get 18 deg advance by 3000 rpm, so I might drop that so that I have full advance at cruise speed.
I need to get an O2 sensor on this thing. Anyone in the Mt. Clemens area that can weld a bung on the header?
BTW, its a 750 DP Holley with a Proform main body. No PV in rear.
