igotaneed4speed
Decided to compile all my crap into one thread, I'll be adding and updating this daily with more stuff as I dig it out so keep tuned in. New stuff will always be added to the bottom of the list.
Everything is Located in Lincoln Park, MI 48146. Call Derrick @ 734-307-40 two nine for questions.
(2) Jegs SBF 1.6 7/16 stud roller rockers
$15.00 Each
(2) MSD 5 boxes NEW
(2) MSD GM waste Spark coils NEW
$30.00 bucks for all of it
Behr Engine oil cooler
$20.00 O.B.O
NEW Edelbrock 1 3/4" to 3" merge collectors. These things cost almost $300.00 http://www.summitracing.com/parts/edl-65803
$100.00
NIB - Stanley Stainless Steel Valves These are the racemaster line with under cut proflow stems, the same valves used in World Products SBF Jr heads.
(8) 1.94, 11/32, +.100 (5.100L) $50.00
(8) 1.60, 11/32, +.100 (5.100L) $50.00
NOS Cheater Plate Kit with under carb solenoid mounting plate, very clean set-up.
$200.00
NIB Cool It 1" header Wrap
$20.00
-New JW bell housing BBF to Powerglide http://www.summitracing.com/parts/jpt-92454/overview/make/ford
$300.00
-C&A 150 series Aluminum Rods for BBF 6.8" long 2.2/.990 pin
$400.00
-Nodular 9" center section, 31 spline spool with richmond 5.67 gear. This is all brand new, still has the set-up marks on it.
$350.00
-Auto Meter Gauges;
(1) 2 1/16 Electric Oil Pressure w/out sender. $25.00
(1) 2 1/16 Electric Trans Temp - no sender $25.00
(1) 2 1/16 Electric Coolant Temp - no sender $25.00
-Virgin 460 block w/front cover and stock heads
$200.00
-460/BBF universal front motor plate (non belt drive)
80.00
-Jaz Plastic seat with cover
$40.00
Used turbo for powerstroke diesel 6.0, picked this up as a spare for my truck, buying a new truck and have no use for it now.
$350.00
$15.00 Each
(2) MSD 5 boxes NEW
$20.00 O.B.O
$100.00
$200.00
$20.00
$300.00
$400.00
$350.00
-Auto Meter Gauges;
$200.00
80.00
$40.00
$350.00
