built 2006 ls1 short block with extras...spun bearing
TSR
update (10-17) lots of engine kicker but no ones pulled the trigger..reduced from $1600 to $900 someone come get it I need the money asap...i took another 12 pictures or so pm a email address if you want them.
SORRY FOR THE MISPRINT ITS A 2001 Block
Engine only had 2000 miles set up for boost but never had any .fuel pump went bad on the hwy and created a spun bearing (thats the only thing I can figure...)when i was trying to limp it home. Rods, pistons, rings, sleeves all look perfect!
2001 ls1 block
Forged Short block built by Force Fed Hp
POLISHED & MAGNAFLUXED CRANK
DIAMOND FORGED PISTONS -8.6cc
DIAMOND 4130 CHROMEMOLY WRIST PINS
DIAMOND PROSELECT RING SET / FILE FIT
CALLIES COMPSTAR LS1 SPECIFIC CONNECTING RODS
FEDERAL MOGUL 152M MAIN BEARINGS
CLEVITE CB663H CONNECTING ROD BEARINGS
ARP MAIN STUDS
ARP ROD BOLTS
ARP HEAD STUDS
BLUEPRINTED & FULLY BALANCED
Extras Included for engine (ALL extras from the other engine i picked up...there from a stock short block with 60k miles)
valley cover
cam gear
oil level sensor
cam sensor
Price is $900 pick up only
[email protected]
Call or txt to 248-830-1867 engine is located in Clarkston, mi
not trying to be a dick but how does a bad fuel pump cause a bearing to fail without piston failure from detonation? squashed bearing? how bad is the crank?
no not at all....i know it doesn't make any sense I understand that....your close by why don't you swing by and take a look.
If the car is EFI a bad fuel pump would of just shut the car off. Something else went wrong. Not a bad price for the parts though. GLWS
