rockthemullet
Specs on the car:
99 Cobra
Vortech S-trim, 10.5lbs (at 6000rpm)
Power Pipe
50lb injectors
80mm MAF
Previously Ford GT (supercar) fuel pump, now Denso ~255lph
KB BAP
Dyno tuned w/ SCT chip
Background:
I shattered the rearend recently. The car has been down since then. I pulled the whole subframe down, installed a new diff (Torsen T2R and 4.10s) and halfshafts and put everything back in. I also installed a new fuel pump because my last one couldn't keep up (which is why my tuner cut my limiter to 6200rpm). I kept the catback off and started it up. I let it warm up to operating temp, resting at a 950-1000rpm idle.
I took the car around the block and everything was fine, felt really nice. I'm headed home, the car is around 3000-3500rpm, and I let the clutch out. The rpms drop and the car stalls out going about 25mph. This is not unheard of for the car, tuner said its the MAF and some weird phenomenon. I normally brake and stay in gear to make sure it doesn't happen. Anyway, even when it does stall out, I can just pop the clutch while the car is rolling and it starts back up, or I can crank the starter and its perfectly fine again.
Today, this is not the case. The car turns over and over but refuses to start up. I tried to run the codes with an SCT X2 flasher and the flasher says it can't read them.
Anyone have any ideas? I would appreciate any feedback.
~Eric
99 Cobra
Power Pipe
50lb injectors
80mm MAF
KB BAP
Background:
~Eric
