slideways
Ok so i got new plugs, wires, cap, and rotor, on today and while i was in the process i took off the AIR pump and capped the lines coming out of the manifold after gettin someone elses mess cleaned up (They set the timing on #4 cyl and had the firing order all friddeg up) ive got the timing order correct allt he wires going to the right place and the base timing set at 6*. The car idles great now at aroun 900-1000rpm in nuteral and around 800 under load. Now when i drive the car it backfires like crazy and i can put the pedal to the floor and it wont rev more then 2500 or so and just backfires more
From my experience this sounds like a MAF problem? i found one vaccume line unplugged plugged it in and did no good, my buddy put the air intake back one so im going to recheck that the MAF is plugged in but im 99.99% sure it is
