Aeromotive fuel pump and filter
mark468
11202 - A2000 Carbureted Fuel Pump
SKU: 11202
From Stock Eliminator to Pro Mod, the Aeromotive A2000 is a versatile force to reckoned with and stands alone as a “big” carbureted fuel pump.
The A2000 flows enough fuel to support the world’s quickest nitrous Pro-mods on gasoline, and is the industry’s only fuel pump that uses a true diaphragm controlled, adjustable bypass valve, integral to the pump. This design dampens pressure spikes, delivering smoother, more controlled flow and pressure, ensuring more consistent E.T.s and win lights.
• High torque, low RPM motor design delivers more than 350 GPH free flow, while developing less current draw than any other pump in its class.
• Adjustable diaphragm bypass valve outperforms ineffective poppet designs, minimizing flow loss and pressure fluctuation to the regulator and carburetor.
• ORB-10 inlet and outlet ports with ORB-8 return and 1/8” NPT gauge port.
like new goes for 369 in jegs and filter is 58 Jegs)
make offer..
• Proprietary seal design eliminates leakage.
• Alcohol compatible.
• Multiple bolt patterns on the bottom of the pump body fit many chassis mounting options.
like new goes for 369 in jegs and filter is 58( Jegs)
make offer..has fittings
