Added some "gofast" parts to my cars
Are you going to be selling that G-force eventually? I'll be looking for one in the next few months...
Never have run it, so I'm not sure what it'll do. One thing I know for sure is that I can't drive it like you do OJ.....that's why I'm going to a C4 over the winter.
Anyway:
351w/60 over.
SRP forged flat top pistons.
Eagle H-beam 43/40 rods.
Eagle 43/40 crank 350 stroke.
Probe main girdle.
ARP rod bolts and main studs.
Competition custom grind 577/596 lift cam.
Aluminum heads with 205/160 valves 210cc runners and 60cc chambers.
Competition pro mag rocker arms.
Competion mag push rods.
Ford Motorsport intake.
Aeromotive 1000 fuel pump, regulator and fuel filter.
AED Holley (4150) 750
MSD shit.....
FMS aluminum driveshaft
HPM subframe connectors,Groundpounder tubular K-member,G.P.tubular A-arms,G.P. coil overs and caster camber plates. Lakewood 90/10 struts.
Flamingrivers manual rack and pinion, manual brake conversion.
REAR SUSPENSION-8.8 rearend,373 gears, Auburn prolocker,31 spline Moser axles, Lakewood 50/50 shocks, Southside upper and lower control arms,LMM drag springs in rear with bag in right rear spring.
G-Force T-5 tranny
Thanks Eddie! It needs a paint job, but all in all she'll do.
Yup! I'll be pulling the motor and trans out by the end of Sept.
Pm me your number and I'll get in touch right before I pull it so you can check it out in the car.
